It is currently Thu Aug 21, 2025 10:45 pm
PostPosted: Fri Jul 05, 2013 10:11 am
City: Alton
State: IL
Tape? Rubber? Foam?
Inspiring minds would like to know.
PostPosted: Fri Jul 05, 2013 10:16 am
A little masking tape and some aluminum foil.
PostPosted: Fri Jul 05, 2013 10:28 am
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
I used to stuff it full of wadded up newspaper, but now I use balloons.
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Fri Jul 05, 2013 10:37 am
I've settled on a bit of flexible sheet plastic inside cut to fit between the braces and a couple of lumps of foam (car sponge) underneath to keep it up.
Tried a balloon like I'd seen here, but they wouldn't co-operate!
PostPosted: Fri Jul 05, 2013 10:42 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I use the plastic top of a yoghurt container, held in place by a car sponge.
PostPosted: Fri Jul 05, 2013 11:22 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Balloon.
Brian
PostPosted: Fri Jul 05, 2013 11:36 am
+1
Alain Moisan
(Now building just for fun!)
PostPosted: Fri Jul 05, 2013 11:41 am
I have different lengths of 3" foam cylinders that hold cup lids in place. Tape takes too long and once a little dust works it's way into the tape and guitar top, no sticky!!
jw ( o)===:::
PostPosted: Fri Jul 05, 2013 11:45 am
First name: duh
Last Name: Padma
Red balloons, the other colours don't work as well... Is true...laughing6-hehe...
PostPosted: Fri Jul 05, 2013 12:32 pm
First name: Big
Last Name: Jim
Todd Stock wrote:
Small or medium Chinese food takeout containers held in place with a piece of sponge...if you just use a lid, you don't get enough finish on the edge of the sound hole with lacquer (like spraying corners...)...
+1
PostPosted: Fri Jul 05, 2013 12:44 pm
First name: Corky
Last Name: Long
City: Mount Kisco
B. Howard wrote:
Balloon.
+1. Easy, cheap, covers 100% of the hole
PostPosted: Fri Jul 05, 2013 4:10 pm
Last Name: Keith
A small plastic or paper plate, held in place with a piece of foam.
PostPosted: Fri Jul 05, 2013 7:40 pm
Last Name: Flindall
City: Peterborough
Balloon for me. What I like about the balloon is that once you are done spraying what you think is enough coats, you can measure the dry thickness by taking out the balloon and flaking off the finish and measuring it's thickness.
Rob Flindall
Flindall Guitars
http://www.flindallguitars.com
https://www.facebook.com/FlindallGuitars
PostPosted: Fri Jul 05, 2013 9:09 pm
How do you get finish into the edges of the soundhole with the balloon in the way? idunno
jw ( o)===:::
PostPosted: Fri Jul 05, 2013 9:32 pm
Last Name: Flindall
City: Peterborough
The balloon only makes contact with the 'inside' edge of the sound hole (that make sense?). The finish seems to flow down onto the vertical edge of the sound hole with out any problem for me. I suppose if you blow it up to much, so that it sticks through the sound hole, you can't get finish on the vertical lip of the sound hole. I just blow it up until it hits that inside edge and you're good to go.
Rob Flindall
Flindall Guitars
PostPosted: Sat Jul 06, 2013 8:06 am
unless you do no between coats sanding this method will give a false result...the measured thickness on the balloon is going to be more than what is actually on the top
PostPosted: Sat Jul 06, 2013 11:59 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I use a piece of cardboard held in place with a block of foam rubber. Very often, the 'cardboard' is a string package with one corner cut off to fit against the UTB.
PostPosted: Sat Jul 06, 2013 1:27 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
I use the lid from a small coffee can. Fill the inside with newspaper to hold it up. It's the perfect size
PostPosted: Sat Jul 06, 2013 2:46 pm
First name: Jay
Last Name: Gordon
City: Port Townsend
State: Washington
Zip/Postal Code: 98368
cottage cheese container lid supported by scrap piece of foam rubber
PostPosted: Wed Jul 10, 2013 3:39 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I don't bother with covering the soundhole, don't see the point. But then, I don't spray finish! duh
PostPosted: Wed Jul 10, 2013 5:16 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
OK, I know that I'm a little colour blind, but even I can see a conflict here. duh beehive
Alex
PostPosted: Thu Jul 11, 2013 10:23 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I use balloons. A side benefit of using them is you can flake the finish off the balloon and get a good estimate of the finish. Yellow balloons work best.
PostPosted: Thu Jul 11, 2013 11:10 am
First name: Phillip
Last Name: Patton
City: Yoder
C'mon, guys, the color doesn't matter. What's important is that they say "Happy Birthday!" Sheesh, I thought everybody knew that...
Do not use balloons that say "Get Well Soon!". Don't ask me how I know this.
Regards,
Phillip Patton
PostPosted: Thu Jul 11, 2013 11:40 am
It looks like a booby sticking through the soundhole. A green booby. laughing6-hehe
jw ( o)===:::
PostPosted: Thu Jul 11, 2013 12:31 pm
First name: Aaron
Last Name: Craig
State: Missouri
Balloons for me as well. works well for covering sound ports too (two balloons - use the sound hole balloon to hold a smaller balloon in place to cover the sound port). You'd think there may be an issues with getting lacquer in the right spots on the edge of the sound hole, but lacquer seems to flow well into the lip. I'm not looking for much finish in that area anyway (no real need to level or wet sand around the lip if you have thin coats and avoid drips).
Aaron Craig
